Hoping to get out to the new K1 circuit soon with our Rotax max karts. I was wondering if anyone has gearing info compared to Adams kart track?
Taller. My 3rd kart was a Rotax, mind you I used it for visiting guests and run a lap or two here and there to make sure it was all good…if I were to wing it, I’d try a 76 and adjust from there. So one step taller than Apex, 2 steps taller than Adams
Great, thank you! I will try 76 first.
I’ve actually been running an 80 at Adams!
Perfect! In my mind, 80 is your Adams baseline. 1 step taller is 78. 2 steps is 76 so you should be right on! 1 tooth plus or minus is way too precise to guess on a forum, you’ll dial in based on day/weight/preference etc that is up to you. You should be ballpark ok with 76 at K1
