KG Bodywork on OTK?
It’s gonna be hard to bend the Ti brackets if they are made for the M7. Start with regular steel ones first and make sure they will work before buying the Ti ones.
Little update on this. The M7 brackets don’t work with the 507 driver panel. While yes, the upper brackets are the same width as the mounting holes of the 507 panel, there are two issues. One is that the M7 bracket is way too long for the KG panel. The second is that the holes on the brackets are about 30 degrees off from matching the hole mounting surface of the panel. You can make the mounting holes work but the brackets are too long so the panel is super tall above the steering wheel.
The other issue is that the lower bracket is 2-3" too short.
But, I will say, with the correct brackets, the 507 panel does integrate nicely with the OTK M7 nosecone. Nice and flush! Plus, it looks like with the 507 panel, my toes will be covered! On the OTK, my big feet stick up past the nosecone significantly and sit outside the hotdog panel. That should help on the straights. Oh and the panel is definitely lighter than the hotdog. However, it really isnt that much wider. It is definitely much wider down at the feet but up top, the hotdog and the 507 are essentially the same width.
