Hi,
Need to help to measure/calculate Kingpin Angle?
Which and How to use the Laser tools available in the market to measure/calculate?
Hi,
Laser will measure toe and camber directly. For caster you can look at the sweep, get a camber caster tool or try one of these.
Caster will involve a little trickery to measure. KPI, I’m not sure on.
Here’s a guide from Longacre on measuring caster. The process applies to karts as well as cars.
NOTE: Adjusting the caster may have an effect on the camber and vice versa. Double check all your settings before finishing. Be sure to tighten all suspension bolts when done.
WARNING:
Do Not leave the gauge in the hot sunlight or store in a place over 120O F. Breakage of the vials could occur due to heat expansion. Replacements can be ordered from any authorized dealer or the factory. Replacement is simple with no loss of accuracy.
Can I ask why the need to measure castor? I know why we have castor and I know why you would want full, half or no castor. Other than making sure both sides are equal, which can be done with your pills, why the need to measure the angle?
Full, half or none are super subjective terms though.
Also, for karts that don’t have independent adjustment of caster and camber I’ve found it useful to plot out the respective camber/caster angles for each position. Especially if you have an OTK with 20holes in the adjustment pill.
If you want to add some (static) camber, without adding too much caster you can look at your chart and see what pill position will work best.
Ok. I do have an otk with all the holes. But they are marked with arrows and use those as the reference in comparison to the screw hole holding in the pill. I also never mess with anything other than arrows straight forward or straight back for Neutral, full or half castor.
I can see how it could be subjective, but that should only be Kart manufacture to kart manufacturer. Castor for otk should measure the same across all similar model chassis and changes should result in same affect. Discounting and chassis damage or twist. I would think it would be the same for other chassis also.
Hi Bryan,
Thank you for engaging in this discussion.
The reason for the caster data and the Kingpin data is to understand the correlation and to understand and fine tune chassis setup for my son.
I agree with you Bryan, it’s all relative to each chassis anyway, so knowing the actual caster values isn’t really important. You can’t really compare degrees of caster from kart brand A and kart brand B.
You can get a digital inclinometer, zero it on the chassis rail alongside the fuel tank and then put it on top of the kingpin. This will give you an reasonable idea.
