Can I have everyone list all of the 4 cycle specific chassis brands and models?
List of Kart Chassis for Four Cycle Racing
Way to take initiative @PhoenixKartRentals.
This is a wiki post, meaning that most members can edit and update it.
First off, let’s talk about what typically makes “Four Stroke Chassis” different.
Generally more a economical option with less adjustability in terms of camber/caster.
Seat bracket and rear crossbar position optimized for the inboard drive on four stroke engines.
Tube diameter and torsion bar selection tends to lean toward the “softer” side.
If you’d like to go a little deeper on the subject, check out this topic:
Chassis built for lower powered, four cycle/OHV Karting.
ALPHA EXOS LO206
BirelArt AM-29
CKR Stingray
Comet Eagle
Compkart Covert 4R
Coyote Various Models
CRG Tork, FS4 & RS5
DR Tork
Luttrell Racing Ionic Edge
Margay Ignite K3 and K2
TBkart SS55 206
VLR Emerald
Info/links required:
Arrow X3 4s
Benik (Model not confirmed)
Energy 4C
Intrepid FK4
DR Tork is a 4 Cycle Chassis.
Also should mention the following brands as well
CRG RS4
CRG RS5
Energy 4C
VLR Emerald chassis for the LO206
Added CKR Stingray to the list.
Comet eagle.
Www.cometkartsales.com
Coyote
These are the only 2 chassis manufacturers I have experience with. Hope it helps
Which would be the cheaper of all these to start my 10 year old daughter out on?
10 year olds would be on Cadet Chassis which is a different size.
does anyone have a list of the different kart sizes?
I’m getting ready to start ordering all the parts for my daughter and I to build her first kart.
I found two
https://nitro-kart.myshopify.com/collections/chassis/products/rolling-nitro-kart-cadet-chassis
https://www.accelerationkarting.com/crgblackmirrorcadetchassis.html
Is this just for the chassis? These websites are not very descriptive.
The two websites that you listed are just the rolling chassis, you would still need to get the engine, tires, etc
