LO206 Gearing for Top speed-Mid Ohio
I have a 2017 tony kart LO206, I want to go to mid ohio to race this year, what gear setup should I use ( clutch driver and sprocket), basically Mid Ohio is a mostly flat out track, so I need top speed
I asked in the Enduro Go-Kart Racing group on Facebook and one response was “Probably 21 55 ish”. You could start there. For sure, you’ll need a big clutch driver in the 20’s, so you can run that for sure.
Hope that helps.
