Greeting all
I’ve only found a list of torque specs on the Briggs Racing site, however that does not list the clutch to crank bolt. I’m using a Hilliard Inferno Flame and as said, other than “tighten to recommended” I can’t see it anywhere!
On the clutch, I need to run it without the two small, thin shim washers mentioned in the instructions to avoid the bearing outer sleeve hanging out quite a bit from the crank end. Is this detrimental to the function or reliability of the clutch?
Thank you.
