Hi , just wanting to see if there is much power performance increase if the squish on a mini vortex cadet engine is out by .2 ??
I can only give a little general info until someone has some Mini experience.
When you say .2, do you mean it’s 0.2mm larger than it should be?
Looks like the min spec is 0.8mm in which case, 0.2mm would make a difference for sure. BUT more is not always better. There could be a reason for it being set at 1.0mm
