Hi, since my body weight is excessive, I’m 100kg, I was wondering if it would be convenient to soften or stiffen the frame or axle?
What axle you run will depend on how the kart is handling, not your weight necessarily. Your body weight will make the kart handle a certain way probably, but you need to make a chassis adjustment based on the handling of the kart, not just based on your weight and what you think that will make the kart do.
Can’t tune a kart in the garage.
