Mychron 5s 2t display - egt and lap splits
Hey does anybody know how to setup the display so it shows your lap splits up or down and also shows your water and egt temps?
I current use the custom display to show lap number, water temp, egt temp and revs and then the lap time displays for 10 seconds when I cross the start finish. On the custom display menu drop down you can select lap time or split etc.
Any suggestions? Ty
I’m not sure I fully understand what you want. If you put the splits in the track map in RS3 and then transmitted that to the M5S, I believe the +/- Best would be based off the splits. You would still get the whole lap time at the end of the lap, but you would not see a lap +/- Best, just the segments.
Is that what you want?
Nah but it’s sorted now thanks for the reply
