Hello all!
I will apologize for the length of this post as well as any posting etiquette issues that I am guilty of. I am new to the forum and new to Mini biking.
I decided to remove the governor on my Tillotson engine and ran into some issues. From what I’ve read, the stock Tillotson flywheel, rods, and valve springs should be strong enough to handle higher RPMs.
Flywheel Removal Trouble
I tried removing the flywheel using the method where you apply pressure behind it with a large screwdriver or pry bar while gently tapping the shaft to shock-load it. No luck. I then attempted using a three-jaw gear puller, but the flywheel still wouldn’t budge.
Crankshaft Play and Governor Removal
During the process, the camshaft and one of the lifter pushrods came out. I reinstalled them, making sure the timing marks were aligned. However, I noticed that the crankshaft had quite a bit of lateral play—almost like the bearing’s inner diameter was too large for the crankshaft. I wasn’t sure if that was normal but continued working.
Since the flywheel wouldn’t come off, I left it in place and proceeded to remove the governor by taking off the retaining ring and governor arm shaft. Once that was done, I tried rotating the crankshaft by hand, but it would only move a few inches before binding up. I checked for any misaligned gears or obstructions but didn’t see anything obvious. I did notice the crankshaft gear sat about 3mm forward of the camshaft gear, which I assumed was just because the crankcase cover wasn’t installed.
I pushed the crankshaft back into alignment with the camshaft gear and tried again. It still bound up after about a quarter turn. I removed the camshaft and tested rotation again—same issue. This led me to believe the crankshaft shifting forward might be causing the piston to bind in the cylinder.
After reinstalling the camshaft (double-checking the timing marks), I also made sure that the crankshaft gear was no longer extended past the camshaft gear. At this point, the crankshaft rotated smoothly with only normal resistance from piston compression. Thinking I had fixed the issue, I put the crankcase cover back on, refilled the oil, and tried starting the engine.
Recoil Starter Binding
When I pulled the recoil starter, the cord would only extend about five inches before binding up. If I let it retract and pulled again, it would extend fully but felt much harder to pull. The next pull would be short and bind up again.
I drained the oil, removed the crankcase cover, and checked everything again. Nothing seemed out of place, except the crankshaft gear was once again sitting about 3mm forward of the camshaft gear. Assuming this was because the crankcase cover was off, I pushed the crankshaft back into place and tried rotating it—it seemed fine. But after putting everything back together, the recoil starter issue persisted.
At this point, I’m out of ideas and hoping someone here might have some insight.
Questions:
Any ideas on what could be causing this binding issue?
Is it normal for the crankshaft to have some lateral movement in the bearing?
Should the crankshaft gear be sitting farther forward than the camshaft gear? If not, could that misalignment be causing the piston to bind?
Can the stock rods, flywheel, and valve springs handle higher RPMs? I plan to use the throttle screw as a limiter to keep it from revving too high.
What’s the best way to remove the flywheel if I need to replace the crankcase bearing?
Any help would be greatly appreciated!
Thanks
