Need help with tonykart brakes
I have a 200
8 Tonykart venox, and i want to know the correct brake pads and fluid for the front and rear brakes.
I would imagine it was originally glycol fluid in the system, but that doesn’t mean that it stayed that way. You can do a water test with the current fluid to see what type it is.
I’ll probably just get 5.1. Thank You!
A quick correction, DOT 5 is not compatible with DOT 5.1, dont mix them.
DOT 5 lives on its own island.
Thanks. I was under the impression it was formulated to work with both glycol and silicone. I edited my post to avoid confusion.
@EvilBunny208 might be best to do the fluid type check linked above to see what’s in the system already.
I tried the water test and they mixed, but i couldn’t tell if it was just glycol, or glycol and silicone like 5.1
Could I also have some advice on bleeding the brakes, as in all the tutorials ive watched the master cylinder has a reservoir but mine doesnt
Do you have a bleeding tower?
Pics. The process is similar across brakes.
No, would i need one?
It makes bleeding OTK brakes super simple.
How would I remove the old brake fluid?
The old brake fluid gets flushed through as you bleed the new fluid in.
I opened up the master cylinder and the insides are really bad, the spring is rusted and gummed up, and there is a lot of dirt and some corrosion, should I just replace all the bad parts?
I would say thats not a bad idea
Is there like a solution i could soak the master cylinder housing in to clean it, I already sprayed brake cleaner and wirewheeled it, but there a little section in the middle that my wirewheel cant reach.
