13-year kart First Kart and need all new brake lines. Where can I get them? I took everything off and brought it to the best auto parts place in the area but NG. Same at the local auto repair shop. I will try OVRP this weekend but no sure of the chances.
If a factory part is unavailable. Should be able to go to almost any local hydraulic shop. Bring the old hoses and they should be able to build you an exact replica.
eyeball what modern kart has a brake setup that closely resembles yours, find a kart shop that carries spares for that, call them up to verify measurements (length of the sections and fittings). You will likely find a compatible setup. Depending on the age, it may be equipped with Birel parts, so I’d start there
You’ll need to determine what kind of fitting you have exactly, and go from there. I have an older kart that uses BSP fittings, which I’ve had to order off ebay and import from China. The hose itself I used 6mm international hose available at places like comet.
