I need to know how much engine oil a 250cc engine needs, the engine is specifically a Suter Vampire VT250.
Seems like that one has us all stumped
I spent half the afternoon at ‘work’ googling to find the answer. Didn’t find it
I also spent some time searching for it and the only one i could find was for motorcycles which is 1.3 to 1.6 liters.
Can you see a fill to spill plug? Generally speaking if there’s no dipstick on an engine or gearbox there’s usually a fill to spill plug.
I will check now, is it any different to a normal screw? Because it might just seem like a bolt or screw.
Ok, i will check for it, thank you
Ok, i found a manual from 2007 for the engine (all in german), and i had my friend translate it and it said that the engine needs approximately 0.7L of oil 10w40
