I had to do some work on one of my chassis that required me to remove quite of bit of powdercoat and it also has some normal wear and tear as expected, so I am contemplating getting it re-powdercoated. However, I have some questions that I was hoping you all could help with.
Is there a type of powdercoat that stands up to brakleen? (I use red CRC) I am lazy and would love to just fire away all around right rear quadrant… but don’t because it makes the powder coat lose its shine, get soft, etc…
If there is no powdercoat that stands up to brakleen is there paint clear coat that does? (I could paint instead of powder)
Anyone know rough price of re-powdercoating a frame… including all prep and everything? I’m open for suggestions in Central Indiana.
Is there any chance that the heating for powder could impact the steel heat treatment? I know they powder coat it originally… and I know the temperature to temper Chromoly is several hundred degrees higher than powder coat curing temp (and annealing way higher yet) but this is not my area of expertise and just want to verify this isn’t something I should worry about.
I appreciate all the help and advice.
Bennett
