Been wondering how you all manage to do this. I was told to do this to relieve pressure on the valves and to avoid bending the exhaust valve—I get this but my question is finding TDC with the started rope without having to take out the spark plug. I’ve thought about marking the clutch but every time I remove it to service i would think it would be off.
So how do you guys make sure you’re pulling the engine over to TDC after each session?
my understanding is that the valves are closed during compression. on my hilliard clutch its impossible to see the clutch shoes that are fixed to the shaft. there must be another way.
Thank you, this is what I was looking for after being told to pull the engine over until it stops. I was watching a BS 206 seminar and saw it mentioned and been told by a few people at the track that it’s free insurance on compression loss and bent exhaust valves. Perfect. Thanks again.
It is to keep the hot valve flat & concentric with the seat. I thinks it’s a low percentage potential problem not so much a definite problem. Maybe some don’t run as rich as others.
Maybe some paint you could see through the holes in the clutch drum.
I don’t think there is much visible on the flywheel side bit a similar mark could work if visible
Sound like your gonna have it by feel though.
I’ll probably start doing it now because of this post.
You’ll get a feel for it eventually. Like it was mentioned before you pull until there is a bunch of resistance and it almost feel like it “rolls over” and then there will still be a little resistance. That’s what you’re feeling for.
