Question about L206 Engines?
I know I might get flak and that’s ok on this question. But just curious why are there so many L206 engine builders. Arent you suppose to run with a out of the box spec. Briggs L206 engines with no modifying ??? To keep cost down. Seems fishy ? Am I missing something here. Being a old engine builder myself ?? Isn’t there tech check on this matter ?
I dunno but I bet it’s float/lash, carb, break in etc. basically bolt on and race it.
its basically just setting the carb up as a good baseline(float, needle height), setting valve lash and rebuilding the top end (if it needs it)/break in (if new engine), stuff that everyone can do at home but your paying for the experience of someone to do it
In addition to paying for someone to give the motor a once over it also buys you an ally that can advise on issues or make recommendations on gearing or changes on settings.
Think of having a builder as an extra round of QC and a support plan.
Calling them engine builders is a bit of a stretch. There isn’t much in the way of legal engine mods that can be done. I think it’s just the default definition/name we all use.
The main thing with the LO206 is valve seats, valve lash, and carb float/needle. The exhaust valve in particular is prone to leaking, especially when first heat cycling the head on a new unit. Many many people are not comfortable undertaking any of that work and send the motor off for someone else to check and set, then they never adjust it until next interval. You can’t crack open the block, so not much in the way of engine building is actually possible.
You’re paying for someone who dedicates their time to finding every advantage possible legal (or illegal) for your specific engine platform. Out of the box engines will not win races against tuned engines, despite what people will tell you.
However, the best engine in the world will not help you if you can’t drive the kart.
My theory is that it’s two-fold:
  1. There’s a 15-way tie for “the best” because there’s not enough of a difference to break the tie
  2. Local support matters. The builders are often at nearby or critical races, so it is very valuable to have them physically on site for help when something goes wrong. Buying their engine package is basically the membership fee for support.
Nowhere was it ever stated or implied that this is an out of the box only class. What is sealed is sealed, what isn’t, isn’t. And $500 or less is a cheap way to make sure what isn’t, is right.
