Hey guys, I’m trying to get the optimal set up for a VLR Emerald Lo206 running at Norway in IL, also known as Concept Haulers Motor Speedway. I don’t have the means to have very many tools with me at the track, so I’m trying to get the set-up as close as possible while at home. What gear do most you guys run in the dry and also any info on ride height would be appreciated.
Chris Rossiter Runs a VLR there. Seek him out on Facebook.
16-56 is the ratio I run and I have not had to change it once this season. That always has me in the ballpark.
I don’t have a VLR, but I do have a 4 cycle chassis. Leave the ride height in the middle to start. Put the rear track width very far in. I had to cut the axle on my kart to get it further in. From there I would play with the front width to get the balance of loose vs. tight where you want it. Air pressures would be something to play with as well.
Follow the VLR baseline setup and adjust from there: VLR_setup.pdf (125.7 KB)
Don’t be afraid to go 20+ psi in those tires…
Thank you, that’s incredibly helpful info!
What tires do they run?
MG Blue …
