Hello guys! Hope you are doing well. I have some general questions before swedish nationals. And they are:
im tearing down my chassis is there aomething specific to look for and to think about when assembling?
how do you guys clean axel bearing from bearing lube… i use brake cleaner and just spray it but my bearings get bad from tbat after like 1/2 of a season…
prepping the chassis (setups and other important stuff)
Thats most of it as of now…
For engines i dont really have to worry bc my engine builder has them both for a race prepp and piston change…
And the last question is:
The nationals are split in 5 days. How do you guys recon i should even out engine usage to perform at max? Like what days to use engine.
Its
-vPractice day
practice and quali/heats
heats
heats and super heats
-Prefinals and finals
So its alot of driving compared to a normal layout on 2 or 1 day…
Thanks for your time. If you want me to specify something pls let me know
Are you allowed to check in and use both engines for the race sessions, or must you only use one? If only one, then it’s self-explanatory. If using two, then I would first ask whether they perform equally, and if so then you could divide the team up by each day.
Yes i can register 2 engines and switch betwen sessions… thay both run equaly on the dyno. 1 carb is a bit better when it comes to idle on the stand but thats not really a problem… @tjkoyen
I will buy 3 sets of tores and use 1 for full day peactise and 1 on practice pr warmup before quali…
But i got some sad news. I will have to either weld ot get a new frame:
I think it’s an easy weld that will have 0 impact on the chassis. Seems like the original weld didn’t have penetration so the crack is really the bead coming off…grind off old weld, lay new bead in and it will be better than new. Bring it to a pro welder and you’ll never notice the difference
