R3 Lasers (Kelgate)
Hi Everyone!
Is there anyone else running the R3 Lasers from Kelgate?
On the caster add on’s there is caster rear and caster forward.
So when reading my pills it is as below:
Max caster with neutral camber reads (Rear -20 ) and (Forward 25)
Min caster with neutral camber reads (Rear -15) and (Forward 20)
So it would seem as the caster is reduced as the numbers also reduce.
However.
If I add maximum Positive camber I get (Rear -10 ) Forward (30)
If I add maximum Negative camber I get (Rear -30) (Forward 0)
This is what confuses me on the caster readings, as I add max positive camber have I added or reduced caster from my max caster setting, same with max negative camber.
Can I just look at either rear or forward caster and as that number increases decreases, thats my measurement for more or less caster?
