I would like an opinion on the rear track width of the kart, as in rotax class we can open the rear track width maximum of 140cm, once by mistake it was 143 and was quicker ( the rear was more stable ) when i realized and set it back to 140 the time went up by 0.250 of a second.
Does anyone know if there’s something that can be set to emulate the effect it had on the kart ?
Was it harder for the rear to lift the inner wheel or easier with 143cm rear width ?
The kart is an IPK
To really advise, you would have to determine why the wider rear track width was faster, because as track conditions and all other variables change, there’s no guarantee that the wide track would be faster again on a different day or track condition.
A wider rear track width will reduce the rate of inside rear wheel lift, so if that’s what you’re after, there are plenty of things to try. The first and easiest would be to narrow the front track width. You mentioned it felt more stable, which is probably the correct assessment in general. When the inside rear lifts less aggressively, it’s more stable and easier to drive. That doesn’t always equate to faster though, it depends on all the other variables at play.
But there are other components to what a wide rear track will give in terms of handling, so something else might be a better adjustment to get you where you want.
When diagnosing any handling issue, break the corner down to its three parts; entry, apex, and exit. If you can identify what it’s doing in each phase of the corner, you can still down to the root of the problem and really determine what the kart needs.
Around 0.400 off, seat is 104 from left king pin to center top of seat.
Last time i checked i was a bit off on the right front but to be honest i dont really weigh to much as i’m already around 3kg over weight so i cant really play with weights.
I’m with TJ on this. Reduce caster, then try low rear ride height. If those changes don’t get you where you want to be, you could move the seat back 1cm, which would also put you at factory baseline (from google search):
