Rebuild questions For Big Block gx390, Predator 420, VC460 etc
What’s the recommended piston to head clearance for these “big block” engines?
If it makes a difference we’re running ARC billet rods. I have 0.040” (1.016mm) as the spec now which seems a bit tight for such a big slug.
Background: Going through the VC460 engines on our rental fleet and noticed we have some witness marks on the piston crown. Admittedly the reason we’re taking them apart is due to smoked rod bearing shells… so it could be just that. I figure since were going though them it would be wise to send them out with sufficient head/pistonclearance. Not looking to set to kill.
Here’s the specs I have for reference for our VC460 with billet ARC 4.510” rods. They may or may not not apply to other engines. Open to feedback on these in a non max performance setting.
Big end bearing (ARC 4.510” Rod): Oil clearance 0.002” - 0.004", torque 120 in/lb, 144 in/lb then 180 in/lb
Crank web diameter: 1.4160" +/- .0005"
Ring gaps
Top (Chrome): 0.016”
Middle (Black): 0.018”
Oil scraper rings: 0.015”
Carnage Pics for entertainment.
Bottom one reminds me of when my x30 blew. What happened there?
Rod bearing let go. Clearance opened up and rod knocked around until kaboom. We have four like that :laughing:
My clearance was as tight as I could make it for squish but we had a 49cc rule for combustion chamber and had to run a 4.410 Rod length.
Our biggest failure point was rod bolt failure or Piston failure
Can you remember where you would end up for head clearance? We try to keep ours around 4200 RPM on track at the peak and maybe 5200 if it’s super slick and the wheel spin is severe.
