The question of how tight a given bolt comes up a lot on the forums so I thought I’d share what I found in Volvo VIDA software a while back. These values are for aluminum threads and I’m going I’m going to assume the values compensate for some vibration.
Bolt torque and clamping force is a complex topic, so if you decide to use these values, it is at your own risk. I’m not recommending these values as such, just sharing the info I found.
in-lb in red as I’ve heard stories of folks accidentally setting their lbft torque wrenches to those values
Maybe you can provide a reference because these are specified for bolts in an aluminum engine.
Block, head, intake, front chain cover etc, all of the steel bolts screwed into aluminum. I would imagine if these numbers are for steel nuts I’d have over 100 stripped threads at this point.
