Removing carbon buildup from cylinder
Hi! Im curious to know how you guys deal with removing carbon buildup in the cylinder and head specially in the cylinder exhaust ports (2 small ones on side) on a x30
I usually use a ultrasonic cleaner with a special detergent but its not so efficient… i heard oven cleaner should do the trick to i dont really know if its safe on alu tho. This what my engine looked like after me and my builder worked on it together using his chemicals…
As you can se absolutely no carbon buildup at all
Soda blaster. Cylinder heads, exhaust ports, piston head. Very fast and 0 chance to ruin anything. Should any residue be left by mistake, it will dissolve
Where does one aquire one?
Amazon, of course! SpeedBlaster
I’m sure you’ll find similar ones on ebay and other platforms too.
Also, when you get it I strongly suggest buying the correct media (sodium bicarbonate) which is coarser than the regular household one. You can steal it from your laundry room too, but it’s finer grit and takes longer to clean stuff with it
Wow, though it was gonna be more expensive, im definitely going to buy it! Thanks
Do you use regular baking soda?
Answer is above :wink:
I use this one, medium grade
image_1636
How long does it take to do the cleaning, and how much media are you using?
I haven’t personally tried it yet, but this stuff looks effective:
Before:
After:
case, cylinder, head takes about 5 to10 minutes, depending on gunk level and if it’s aircooled or water. The equivalent of 2 red solo cups worth of soda.
