Removing wheel bearings front hubs
Hey guys chassis is a birel ry30-s10…wanting to remove the bearings from the front hubs for replacement but can’t seem to get them out…anyone have any idea on the methodology/tools required?
Heat the hubs in an oven and the bearings should fall out or be tapped out easily. Don’t forget to use oven mitts when removing the hubs from the oven.
Since you don’t intend to reuse the bearings you can use many methods.
One is to use a long punch or dowel. It has to be a smaller diameter enough to angle in the bore of the bearing to catch the other side.
Another is to put four splits in a pipe and flare that end. It will pass through the hole on one direction and not the other. You can pull the split into the center of the hub and then reverse direction to knock
out the bearing.
A J-hook can work too if heavy enough.
I use PB Blaster before removal and never seize going back in.
Here’s a video on changing a Tony kart hub bearings, but will apply to you as well.
Seriously?? Just use the heat method that I described above, zero chance of damaging the bearing bore, no special tools needed. GEEZ…
Never wanted car/kart parts in oven. Burnt pizza smells bad enough. A cheap roaster oven kept in shop works well instead
Never said the kitchen oven. I use a toaster oven.
Yes, just heat them, they pop right out.
Thanks for all the replies guys, got em out
