we will be running evinco red tires our first time ever running these tires, and our first time ever road racing also!
what cold and hot PSI do you guys aim for with these evinco red tires?
I’ve heard is not easy to build heat road racing also so we may run a touch higher we will see.
your help is appreciated! thanks!
Which class are you running? I’ve scorched a few sets of tires road racing 125 shifters without a problem .
we’re running 80 shifters at laguna seca. given tires are open seemed like may as well run the sticky tires
I road race a TAG and shifter on Envico reds or MG yellows. Never had a problem reaching an optimal 12-12.5 psi at the end of the run. I start as low as 9 psi on a hot day and 11.5 when in the 50’s.
awesome! thanks that’s what I was looking for.
