Hallo
New to the hobby
I have bought an old Tony Kart from 2012 (dont know the exact model number ? and yes i know its painted “FA blue”)
'Long story short… I was on the track the other day, for the very first time. Until now, I have been running and old Gillard / P.D.B kart from early 2000. But I noticed that the steering was very tough and hard to turn in corners. I had to use a lot of force, and got tired in the wrist pretty fast… What is the default setting for the steering column ?? Do people sometimes run it, in the inner position ?? And if I move to the inner position, do I then need to setup the toe etc. again ??
Your brain is betraying you. Top arrow forward and bottom arrow backward = maximum caster.
So yes, you have maximum caster in the kart @Silverline. If you rotate one of the pills so both arrows are facing the same direction, you will have neutral caster, which will lighten the steering and reduce mechanical jacking.
Correct.
Both arrows forward or backward = neutral
Top arrow forward, bottom arrow backward = max positive caster
Bottom arrow forward, top arrow backward = max negative caster
You can also get a neutral pill that is concentric rather than eccentric, and running that on either top or bottom will give you halfway adjustments so you can do half negative or half positive caster for finer tuning.
For now, I’d keep them both pointed in the same direction and keep it neutral.
