Does a soft seat free up the rear of the kart or does it tighten it down? (I know this is a vague question, but in general)
From what I know from data and track analysis it frees up the rear of the kart( seat would absorb weight and slide more than lift)
but I am curious what you guys think?
Soft seat is going to flex more, allowing the inside rear to lift more easily. You’re softening the connection between the two bearing cassettes, similar to a soft axle.
Typically, I feel like it’ll help it lift easier, but it also is going to absorb some of the force going through the frame, so it isn’t going to plant the outside tire as hard.
