Throttle and Brake Sensor Installation Help
Hi,
Request help to install a AIM Throttle Sensor and a Brake Sensor on my son’s Junior Tony Kart pedals.
Tried looking at videos and documentation but the Pedals seem to be different.Attached pics. of both the pedals.
20180814_14391940820180814_14395741520180814_14400685820180814_143908170
Looks like you’ll need to drill the pedal and install the passive side of the sensors.
similar to this:
Then, you’ll need to install the active side - it looks like you’ll need to weld or otherwise affix a tab to the front bar
I had to mount the sensors differently than the directions showed when I mounted them to my daughter’s DR/CRG chassis. I used the brackets to bridge across from the center. I’ll take pics this weekend and post them for you. It didn’t require any additional drilling.
When I mounted them on our new Benik, I was able to mount them as their directions showed since the pedals mount differently.
Thanks Guys.
Let me try and get back to you guyz with the result.
Hi,
Please post the pic.
Thank you.
These are how I installed the brake sensor on our DR/CRG. I used the brackets that came with it to attach across from the center piece, then I made a bracket to attache the other sensor from the pedal.
2018_08_18_4102018_08_18_408
For the throttle, I just made a small bracket for the magnet.
2018_08_18_406
And our new Benik was much easier with the way the pedals are installed on it.
2018_08_18_4022018_08_18_403
