Scraping the rubber pick-up from the cool down lap off, which we scrub off on our out lap for the next session anyway. Pretty much useless. In F1 I’m sure they are doing it for more advanced reasons because the tire construction is different, and tires are so important in that specific instance.
Basically. Its actually somewhat common here for kid kart/bambinos because they never generate tire temp to scrub the tires and always come in with extra rubber pick up.
We do it on the Porsche’s. It’s done for a couple of reasons; taking pick up off tires that are going to be ran again so the out lap isn’t super sketchy with the marbles. To measure tread thickness to look at tire wear from camber/pressures. To look at the graining patterns.
At OVKA, you cannot tire scrub on formation lap before green. If you do, you go to the tail and so many people will scrape tires with heat gun between heats to get a cleaner tire for Turn 1 and 3 after that the advantage is negligible.
You can’t get the tires “hot” in the rain. It’s more about getting the pressures right to match the amount of water on the track. More water = more pressure to let the tire displace water.
If it’s damp but drying you want low low pressure to keep the tire from overheating and burning up.
But as Dom said aluminum wheels are the choice fit rain since they hold heat better, and they’re softer.
Depending on what rain tire you run… For MGs we’ve run as low as 6-7 psi when the track was drying and we knew we would burn the tires off. We’ve also run as high as 22 or so if it’s heavy rain with big puddles.
Mag wheel will be fine if that’s all you have. Aluminum is also typically cheaper though so if you wreck one (which easily could happen in the rain) not so bad to replace.
