Tire Warm Up
Is there a better and quicker way to warm up your tires other than sliding around in the corners and brake then accelerate then brake then accelerate? This is my current way of warming up my tires and I would like to know if there’s a better way.
Core temp is what you’re mainly trying to achieve when you warm up tires from what I understand. You’d want to work the tires best you can in the corners
How can work the tire in the corners to get heat in the core? By inducing understeer?
Just get the kart loaded up in the corners drive in hard etc
Long duration turning will heat the core of the tire.
Sliding will heat the surface.
I like to do big sweeping tire scrubs on the warm up lap in the straights, and then do big steering inputs to induce under and oversteer in the corners.
