Does anyone know which hole/bolt is the gear box oil weeping hole?
I’m assuming that you remove the bolt and check the oil level periodically?
Thanks
Thanks
You do not need to use that. At least every 2/3 hours drain and fill to correct amount, you won’t give the oil level a chance to get low in the first place. Cheap insurance, happy gearbox ![]()
How much fluid does it take?
300ml of ATF or Extra Light 75wt gearbox oil (like Maxxima MTL)
