So I got a used Rotax Max Evo. Measured compression at 150 psi. I’m jetting it pretty rich and it sounds like pinging (but not in rhythm…more like a loose metal part inside).
It revs, starts, runs just fine.
I heard that Rotax Max can sound like loose metal banging inside the engine when you need a top end rebuild…I’m asking for sanity check.
its hard to say without listening to the engine but this may not be pinging at all, but the metal on metal clutch. The metal clutch on the rotax make a dinging noise, almost bell like when engaging.
