Just curious if any of the briggs engine gurus use leakdown testing as a diagnostic tool for valve life?
If so, what parameters are you using? How many PSI, how long do you let it sit to measure leakdown?
100psi on a block off plate. It’ll hold constant pressure forever.
What about on the engine? Is it a good diagnostic tool?
Not as helpful on the block side.
Derek is correct. You will have some inherent leakage around cylinder that can make diagnosing a valve leak more difficult. It’s the test I do, but only because I haven’t found a blank plate and now we are looking at 2 stroke for next year, so no worth chasing.
Leakdown testing is a must. And if you are running with the fast guys, it matters. A leaking exhaust valve is pretty common on these motors and my son says he can notice a loss in mid rpm and top end power when it starts to leak. Almost every time he reports it, I find a leak. When I check it when he hasn’t complained, no leak.
For what its worth, I’m going to design myself a little block-off plate with a M14 threaded hole in the center so I can do a leak down test with the head off the engine. And I’ll be able to do leak tests on each valve individually by inserting air through the ports rather than the combustion chamber. That should make isolating any leaks easier since you can rule out your block.
Might be able to make several extra sets if anyone on here is interested in them!
You’re making it way too complicated. You can hear and feel where the leak is.
Get a piece of scrap plate and mark the holes with a head gasket and drill them. Send your air through the spark plug hole.
Added:
At the end of the day, it doesn’t matter what valve the leak is coming from because if you have the head off and you have a leak, you need to work both seats anyway by either cutting or lapping and drop in new valves and springs.
True true, I didn’t even think about making a plate to cover the combustion chamber.
I’m with you, if I’m going to do any valve work, I’ll be doing both valves. I’ll dig out some scrap aluminum this week and make a plate, then order the Neway valve cutters.
Is there a method to determine whether the valves need cutting or lapping?
That is the purpose of the leak-down test. You force a bunch of air into your combustion chamber, and check for any air leaks (which you will be able to feel and hear). If you hear/feel any air coming out of your intake and/or exhaust ports, then that’s your indicator that you have a leak at your valves. then you look into lapping.
some leakage is expected though, especially on a cold engine. But as long as it’s minimal you’re okay. A leakdown tester kit will tell you exactly how much air you’re losing.
Sorry bad question phrasing on my part I meant cutting vs lapping how do you determine which to do?
I’m fairly new to engine building, but have 20 years in tool and die making. Lapping is reserved for fine fitment work, on parts that are almost perfect, its not really of any use for material removal. Ideally you’d cut the seats, then give the valves a quick lap to confirm the new seat face and valve fit perfectly.
Another thing you can do with lapping, is mark the valve seat with something like a blue sharpie, then lap your valve on it for a few seconds, and check to see if the blue has been rubbed off consistently all the way around the seat face. If you’re virtually there, you can possibly get away with lapping compound to clean it up, but if there is a lot to remove, or there is visual damage/pitting of the seat or valve, they will need to be cut.
