Hey guys, can any of you gentlemen that build briggs engines, suggest a seat cutter kit for the LO206 heads.
Neway cutters do a good job. There is an animal/206 kit with the correct cutters and pilot. If you are doing just your own heads the T handle is adequate but the the turning tool, either manual or electric, makes it easier to apply constant, even pressure. The T handle just requires some practice
Thanks, I’ll check this one out. I have to get my milling machine setup, and practice on some old Honda heads I have laying around from the days of my son racing box stock Honda.
Neway 30 and 45 degree cutter heads, centering tools, and the spring loaded cutter handle.
