Venturi Tuning VHSH 30
Is there any tuning that can be done to the venturi on the dellorto float carbs?
Or is it a case of just ensuring its aligned properly?
check that post .
i am just aligh and service them according to my manual .
but i am just a hobby driver .
There are different nozels you can change but the shorter you go you must add fuel as it doesnt atomize the same as a long nozel the shoerter nozel increases air flow while decreasing fuel flow hope this helps
I just remember having a conversation with someone years ago while racing rotax and they were saying the difference between a good carb and a bad one was the venturi. They said gains were made aligning them etc.
I run open rules, so I was wondering if it was something to dive into some more.
What does “aligning the venturi” mean?
