Hello. I’m trying to figure out what I need to drain in order to vertically store a CR125 and a DD2. I have to make room in the garage for the trailer.
The dd2 will be ok , i keep mine vertical most of the tine , I’m not sure about the cr125 but if you can block off the gear box breather it should be ok .
You’ll need to drain the carb and fuel system in the CR, otherwise it’s going to leak on the floor.
