Hi, My sons cadet vortex mini rok clutch has been slipping on take off but runs fine when he is going, so I have replaced clutch, clutch bell and roller bearings, all fine on warm up when the kart is on the stand
but when he sits in the kart and puts his foot down to go , the kart doesn’t pick up the revs , and only goes at walking pace , any suggestions on what is happening, many thanks
If it doesn’t “pick up the revs” then the clutch is not slipping but rather engaging at a very low speed and causing the engine to lug down to well below a good speed range to make power, causing slow starts.
Try measuring the clearance between the clutch shoe and drum and comparing it to the specification.
Alternately, the compression, carburetion, or ignition could be wrong and that would cause it to be slow at lower speeds.
You can avoid clutch problems by removing the clutch and installing a direct-drive sprocket on the crankshaft. If it still pulls poorly out of slow corners or off the grid when push-started then it’s an engine issue.
So I’m not super familiar with the Vortex engines, but if they’re like the IAME Swift equipment, I think that might just be normal for them. I know the Mini and Micro Swift engines don’t get going from a stop very quickly, just because of the low-stall clutch and high rev range. Is his kart taking off significantly worse than the other Mini Roks he runs with?
Hi, thanks for your suggestion of the motor, it was even more simple than I could have imagined, due to having a new clutch they are to grippy and a little crc sprayed onto the clutch bell is needed ,until it has a small amount of chain oil etc build up , cheers Andy
My son’s Mini Rock is doing the same thing. Did just some CRC spray in the bell continue to work? We purchased it used and all was going well. He was driving in a parking lot to learn the kart and crashed up a curb, down a small hill, and off another curb. Everything looked fine minus a bent wheel and the chain fell off. Ever since then, his kart runs great on the stand, but once he sits in it on the ground, it boggs down and does not spin up. I tried to add some lube to the clutch and it did not help. Is it possible that the clutch could have went due to this crash? I just ordered a new clutch and clutch bell.
