VR Headsets
From what I read people really like the Facebook vr units. Would be a good way to try since they aren’t super expensive.
Interestingly the quest 2 is less expensive than the Lenovo was on sale years ago. If I’m reading this correctly the 2 is $200
This also appears to be a wireless unit. Says 2 hrs. But, apparently you can double this with battery pack.
Memory is probably what its stores games on since I think this is truly standalone. @tankyx any clue how this one works? More is better I am sure. But it might just be storage of titles and not performance related.
@tankyx also… how does this work in context of pc video card? Is the oculus driven by onboard chip?
For the Quest2/3, you can run apps directly on it but don’t expect to run games. You can stream some VR feed from the computer, with quite a bit of compression or wire it directly to the gpu like a usual VR headset
Okay, good to know. So for sim racing, if you’re plugged in, the memory in the headset isn’t worth the extra expense?
No it is not worth it
