A bit of an old topic, but hear me out as I have some controversial observation. Here’s some background to start:
- I have a 2024 Tony that I used for 1.5 seasons and have counted 60 hours on this chassis so far
- Rotax Senior engine, 365 lbs class weight
- Bit of a tall driver (187 cm, 180lbs)
- My local track has a good amount of grip and we use Levanto KRT tires (similar to LeCont whites). I run into similar issues on other tracks too though, but less prominent.
This is my first OTK kart. First ~20 hours of use, I had no issues - good balance always - race day or green track. Then, it started to understeer when the track is gripped up. Understeer happens after initial turn in and to the apex (from 15% to 50% of the corner, if it 's clearer).
On a race weekend I usually run full caster, stiffer front bar, the rest is mostly standard setup. Full rear width, 1 large spacer on the front, ~1mm toe out, 0 camber. Also I run a harder axle (type A or H).
I tried different setup changes but nothing really helps. So having exhausted normal options I decided to experiment with weight balance. I don’t have much lead (4 lbs) but I also moved the seat 1-2 inches. When I moved weight forward, that didn’t help (although I expected it to help). And then, when I moved it back to where it was, and even a little further back - suddenly it seemed to help. It’s hard to say for sure because the 2 sessions were more than an hour apart and the track could fall off a bit, removing the condition for understeer.
That’s one thing. The other thing, with driving, I noticed that if I add more trail braking, it makes more understeer. When I add throttle at apex, it adds a little more rotation (not to be confused with rear sliding).
So, with both static weight distribution and dynamic (brake/throttle), it seems like adding weight to the front creates understeer, and adding weight to the rear helps with it. Which is opposite to what we usually expect.
Wanted to hear everyone’s thoughts on this, and whether you ever experienced something similar.
I will try more testing myself, but unfortunately this has to wait until the next race as the problem never surfaces on a green track.
Also, not sure how much can be perceived from the video, but here are 2 videos.
The first is on an odd day with green track, kart feels balanced:
Second is from a race weekend session (some lack of front grip or overgripped rear):
