Should I use a rubber cement? Or? Thanks.
You’re talking about your decal kit peeling?
I’ve used spray adhesive with some success before.
Yep some Super 77 should do it. Try to clean under where the sticker is coming off. Maybe rough up the plastics with SoctchBrite and clean debris off the sticker adhesive is anything is on there.
https://www.homedepot.com/p/3M-13-8-oz-Super-77-Multipurpose-Spray-Adhesive-77-DSC/316334789
This stuff… It’s a little pricey but the best way to make decals stick to low surface energy plastics. This stuff pretty much welds vinyl on and works great to seal down those stubborn corners. They also make paint marker like pens full of it too that work pretty well.
Amazon.com: 3M Primer 94 1/2 Pint | Car Wrapping Application Tool : Automotive
I ude the 3M primer 94, great stuff.
The front bumper i prime before even trying to fit the stickers.
I always carry clear bra in the trailer and just use clear bra over corners that start to come up. Not the prettiest solution up close but it’s effective and can’t be seen from too far away.
