X30 Carby Lever Height
Do any of you guys change your lever height? What would the idea be adjusting the lever height slightly above the carb body, and vice versa?
Well the theory is you will run leaner or reacher in all the rpm ranges if you adjust that … dont remember if you are above surface and via versa what is gonna be . Sure the other guys here will tell …
The one i know for sure from our engine. An iame 175 super is that we got the adjustment flat all the time and we didn’t notice any big differences with playing with that adjustment…
But on that system and on that carb we have seen major almost miraculous changes with the engine performance , by changing and testing the spring in the needle on that system …
Tillotson makes several types with different strenth and it could be some waiting to get the parts from ireland . But its worth it .
And those guys are super helpful !!
