Is IAME overly conservative with their piston fits? I have had a used X30 in a box for a year and I am finally getting around to putting it together. The X30 overhaul manual calls for .11 mm clearance. Seems awfully loose.
I have always fit pistons tight on my own motors, but I am VERY careful with break in. Back in the day, for my best KT100 race motors, I would fit them at .0024"-.0026". In recent years, I have been working more on dirt bike motors, so may have lost my frame of reference…
For a 54mm bore water cooled iron liner motor, .085mm (.0033" +/-) seems more reasonable…
Assuming that it would be similar to the Parilla Leopard and with my experience with those engines clearance should be .005+. I know that goes against some of the principles on water cooling but the Leopard at least had to have that much clearance or it would stick before even broken in.
Thanks for the feedback. Now that I think about it…ALL the water cooled cylinders I have worked with have been motorcycles - NIKASIL. And all the iron liner engines I have worked with were air cooled. So I do not think I can draw any conclusions about IAME being “too conservative” in their fits. I will stick with the manual - .11mm.
Thanks…I am aware. Helpful for making sure you order the correct piston. I will say it is very annoying that IAME does not make any 54.07 and 54.17 pistons…
Green Dot means add .01mm to size marked
Red Dot means add .02mm to size marked
So, 54.10 Red means the finished cylinder bore should be ID 54.12. With a piston fit of .11mm, that means the actual piston skirt dimension of a 54.12 Red is 54.01mm!
It would be a heck of lot easier if they just put the actual size on the piston, and let us do the math. We are not going to trust what the piston mark says anyway. We are going to measure the skirt, and hone to our fit.
No. .11 is on the tight side for an X30. Iron bore TaG engines need loose pistons, as much as twice the clearance of a nikasil cylinder. A shifter builder I know stuck 2 X30’s in back to back sessions because he built them like he was building a shifter. As far as how Iame’s piston marking/sizing works:
