Briggs & Stratton 206 Engine Rule Update – Non-impacting, effective immediately
- Cylinder Head – (Updated 2/18/2019)
b. Cylinder head must be “as cast”. Factory machining marks on the head gasket surface is NOT a tech item.
“As we continue to advance the machining of our cylinder head the need for a gasket surface finish is no longer necessary”, stated David Klaus, Director – Briggs Racing.
“We made a promise to the sport 9 years ago about maintaining competitiveness right from the box. We are proud to continue to tighten our tolerances and hone our efforts to a precision that others won’t follow because they can’t or the cost to do so is too great. Our combustion chamber tolerance was a fraction of the thickness of a hair and we have reduced that fraction in half. While our previous tolerance would never be seen on a dyno, now there isn’t even a discussion point.”
Racing is a passion that we do full-time. Providing stability through hand-built precision that is back by a consistent rule set provides the cost-effectiveness that families deserve and our sport needs. This IS Briggs & Stratton Racing.
