n.b. as of 5/31/17, the GoPro 5 is not supported by the Live4app listed below.
Use this guide to stream live onboard footage from your kart. We will send the video from the GoPro over WiFi, then use a smartphone and an app to broadcast that video to the web.
Footnotes…
- The phone you are going to use will have to come with you on the track. You can put it on the kart somewhere securely, or even in your suit pocket
- Remember to keep the GoPro and phone in wiifi range while broadcasting.
- Sometimes resetting the wireless password on the GoPro can be a bit tricky, so it’s best to get it connected to your phone as soon as possible.
You will need:
- A GoPro with Wifi
- Smartphone (iOS or Android) that you will take onto the track with you.
- GoPro App (Free)
- Live4gopro app (Also Free.
Step 1 - Pair your GoPro camera to the phone over wifi
Install the GoPro app on your phone
Follow the pairing guide for your model of GoPro on this page: https://gopro.com/support/articles/how-to-pair-the-camera-with-the-gopro-app
Click here if you’ve forgotten your GoPro WiFi password. The default is goprohero
When pairing is complete you should be able to see video from your GoPro on the screen of your phone via the GoPro app.
Step 2 - Setup Live4GoPro
Grab the Live4GoPro app for Android or iOS
Launch the app and setup an account (only takes a couple of seconds with twitter or facebook)
Once you are logged into the app, tap the red + at the bottom to start a stream, then tap gopro at the top to select your camera.
That’s it! You’re live!
Example
Here’s what I got from Josh Lane and Killian Keavaney at Rock Island in 2014
http://live4.io/stream/kartpulse
