We have the same as Gage, the 5 degree Odenthal. Whatever you get, you’ll want at least the 5 degree.
As for oil, if you run any SKUSA or IKF sanctioned event, it will have to be 16:1 (8oz to gallon). I’ve always ran 16:1 in all our 2 strokes, as it helps preserve the engine life, and still creates good power.
I am in Syracuse, NY. Our local track Lafayette Motorsports Park is moving into the KA class, so mostly club level. I used Redline in my KT then switched to Motul and will probably stick with the Motul.
Not that my opinion matters to anyone, but that track is ridiculous. It reminds me of the track at Lubbock Texas. One big long straightaway with the rest of the track a bunch of tight turns and short straightaways. Really really hard to gear for!! Extremely hard on clutches.
I don’t know about you, but I wouldn’t relax me going down that straightaway, I would just be worried about winding the engine too much.
It becomes a test of whose engine will stay together, down the straight, once you get the gear set for the tight stuff. It becomes a a test of who can gear the lowest and still not get past down the straight. You won’t see them building tracks like that in Europe.
I think a lot of 2-stroke race motors don’t use rev limiters, even today. My TM K9 doesn’t have a rev limiter. Generally it won’t make enough power to spin the engine any higher than 15-16k rpm due to carb sizing; but, there’s no ignition cut to stop it from going higher.
Today’s motors have better quality materials and spec’s that make them fairly reliable. But take any motor, reduce the squish down to almost nothing, turn them at 17K for long periods and you’re asking for problems. At 17000 RPM, the piston is traveling up & down about 280 times a second. Any stretch in the rod and the piston will introducing itself to the head.
Seems like it could be similar to a Speedsportz ratio with the long straight and pretty fast tight corners but I don’t remember what people ran for KA there in the past.
The track map is decieving, the track is actually pretty fast and the hairpins are practically non-existent.
Here"s some onboard of Zach Holden a few years back winning there.
Granted this is x30 but still gives a good idea on corners. He sits on the rev limiter for half of the straight, so I imagine that gear for a track like this would be similar to NCMP.
That gearing sounds fine. The only place you would have clearance concerns would be the exit curbs in turns 6 and 7, but I don’t know if they let you go 4-off there like they do at national events anyway. Plus a 79 would probably clear that just fine anyway.
