Kart republic Information
Maxxis sport tyres - KA100 unrestricted.
In general a longer wheelbase will provide some stability. That could help the situation you describe.
I have a kr2 2021 . What should the camber read when the adjuster is set to neutral or dot forward? Im trying to find out how jacked up my kart is. I bought it and guy had full positive camber built in and when i got it home it was reading negative on both sides. Trying to straighten this flex out. Wont ever buy a kart without lasers again!!
You NEED lasers with the KR! It’s an excellent chassis but the line-up camber indents can be off (apparently some just ship that way). As a result, the small retaining camber screws won’t necessarily align with the thread holes, so really tighten that kingpin and check there’s no subsequent movement on the camber dial.
Right now i have both camber dots straight forward. One reads 1 dot or half box negative camber other reads 2.5 boxes negative camber
Not unusual, similar to ours! Just reference the lasers, that’s all that matters.
