"Miata" Horsepower for Karts
I was curious to compare how various kart classes compare to a spec miata adjusted for power/weight. It was interesting and lower than I expected… Could be my math as well.
Taking a Miata to be 2400 lbs (putting a 200lb driver in there) developing 125HP
Briggs 206 at 360lbs = Equivilant to a SM with 73HP
World Formula at 360 = Equivilant to a SM with 100hp
KT100 at 360lbs = Equivilant to a SM with 120 HP
TaG at 360lbs = Equivalent to a SM with 187hp
Shifter at 385 = Equivalent to a SM with 280HP
Superkart at 450lbs = Equivalent to a SM with 480HP
But then you start talking about lateral G than a kart can hold, and then everything is out of the window :stuck_out_tongue: lol
A 1.6L NA Spec Miata can be as low as 2040 lbs without a driver.
Isn’t the Elise 200hp @ 2000lbs? Or is that English lbs which are not the same as US lbs?
Well yeah, and the rate that turns “attack” you on a kart track.
lbs are the same both side of the pond. Tons/Tonnes and Gallons are different though. Often when karting is compared to spec miata (or vice versa), so I thought it would be interesting to through some numbers at it.
Briggs 206 (8.8hp) at 360lbs = 40.9 lbs/hp
World Formula (12hp) at 360 = 30 lbs/hp
KT100 can (15hp) at 360lbs = 24 lbs/hp
KT100 pipe (18hp) at 360lbs = 20 lbs/hp
TaG Leopard (27hp) at 360lbs = 13.3 lbs/hp
TaG X30 (30hp) at 360lbs = 12 lbs/hp
TaG Super X30 (43hp) at 360lbs = 8.37 lbs/hp
CR125 Shifter (40hp) at 385 = 9.6 lbs/hp
TM KZ10C Shifter (48hp) at 385 = 8.02 lbs/hp
Superkart (100hp?) at 450lbs = 4.5 lbs/hp
Yes but what’s all that in “Miata HP”
FINE.
Briggs 206 (8.8hp) at 360 lbs - 40.9 lbs/hp
World Formula (12hp) at 360 - 30 lbs/hp
KT100 can (15hp) at 360 lbs - 24 lbs/hp
KT100 pipe (18hp) at 360 lbs - 20 lbs/hp
Mazda Miata 1.6L SM NA (116 hp) – 19.8 lbs/hp
Mazda Miata 1.8L SM NB1 (123 hp) – 19.5 lbs/hp
TaG Leopard (27hp) at 360 lbs - 13.3 lbs/hp
TaG X30 (30hp) at 360 lbs - 12 lbs/hp
ICA (28 hp) at 310 lbs – 11.0 lbs/hp
Focus RS (350 hp) – 10.5
FSA (32 hp) at 310lbs – 9.7 lbs/hp
CR125 Shifter (40hp) at 385 lbs - 9.6 lbs/hp
TaG Super X30 (43hp) at 360 lbs - 8.37 lbs/hp
TM KZ10C Shifter (48hp) at 385 lbs - 8.02 lbs/hp
Mustang GT350 (526 hp) – 7.5 lbs/hp
Ferrari F40 (471 hp) – 6.8 lbs/hp
Ferrari F430 Scuderia (503 hp) – 6.7 lbs/hp
Chevrolet Corvette C6 Z06 (505 hp) – 6.6 lbs/hp
Chevrolet Corvette C6 ZR1 (638 hp) – 5.6 lbs/hp
Superkart (90hp) at 450 lbs - 5.0 lbs/hp
C-Open Vintage (76 hp) at 350 lbs – 4.6 lbs/hp
McLaren F1 (618 hp) – 4.4 lbs/hp
Bugatti Veyron (1001 hp) – 4.35 lbs/hp
All street car numbers were calculated using a 200 lb. driver added to the published curb weight.
All street car horsepower number are published, non-dynamometer values.
Crap, my son runs Briggs animal road at 305 12hp 25 lb/hp
Your Miata equivalent HP is 94
I think your Superkart HP is high. I’d guess it’s closer to 65-70hp
I’d agree that 100 is high, but 65ish is what singles make. Twins are closer to 80-90, especially the likes of the 250GP based ones, PVP and so on…
PVP, BRC, and Gas-Gas twins are often reported north of 100 hp. Rotax and others are around 90, So anywhere in between. I’ll revise it to 90hp just in case.
That’s where the fun and debate starts with dynos… I think 100HP or anything north of it is #FakeNews to be honest. Like the 36HP formula super A motors :laughing:
Dynos vary so much, as well as operators and of course there’s always our friend the “trophy pull” where a motor makes great peak numbers and either would blow up, or be useless on the track.
Riley Will would be a good guy to ask. I trust his methods and judgement.
