Minus running the wrong fuel, that would be a lot of fun. But I’m about 310-315 total weight with no weight on my kart. You would have to be under 140lbs to run that class competitively.
Oh, yeah, that would explicitly be a light class for light drivers. We need a class for light drivers, though, and being light really improves a 100cc much more than other classes. It’s fun to watch someone driving something as agile as a 100cc on sticky tires, moves that can’t happen in other classes happen there. If being right on the edge of mechanical disaster doesn’t improve the driver or spectator experience then I don’t mind this being run on 93 octane fuel.
(light class ka100 at 320 lbs, medium class TaG at 370ish lbs, heavy class shifter at 410ish lbs is a nice split and gets you down to three adult two-cycle classes)
155kg aint light needs to be sub 150kg at least before we’re talking. 100 Britain used to be 132 and 100 National 135kg. Karts got BIG
Yeah, if the lighter class really takes off then people will think about a very light class, but right now a 320 lb class just needs a 145ish lb driver, an ordinary 30mm modern kart chassis, and a lot less lead. For any of these I’m just a spectator, my 190 lb body suits a shifter best…
Hi All!
Very happy to have found this forum yesterday as I’m looking to restore my old karts/engines. I haven’t raced my karts in probably 15 years now as I’ve been busy raising 2 daughters. I would like to refresh them all this summer and get them ready to go test them in the fall.
I have an old KT100 with a Walbro carb, a Rotax rotary valve (not sure which version but a 93 vintage) with an Ibea carb. I also have a Parilla Leopard TAG engine. I’ll post pictures here to help aid in deciphering.
I last used the Rotax and the Parilla about 15 years ago and they both have limited hours on them. The KT100 is of unknown hours as I don’t know how log it was since a refresh.
I basically want to get suggestions on how I should go about checking them over and what to replace. I assume I would need to refresh the carbs. Not sure if I need to replace the oil seals. Not sure where I can even get replacement parts. Not sure what else I should look out for. Also not sure where I can find bolt torque specs, disassembly manuals/videos.
Normally, I would go to my engine builder Anthony but he passed away due to Covid. I want to respect his engines and try to do the best job I can and bring them back.
Thanks all in advance for the help.
Kevin
The Rotax is a DSC. Depending on how they were stored they might be OK just having crank seals replaced. Often though you end up with a small amount of rust on the rod ends and or crank main bearings that can be terminal.
Unfortunately those parts are impossible to see with out disassembling the engine.
Worth having a look inside and try to gauge it.
Thanks for the quick response!
Unfortunately “They” is “Me” and I’ve kept it in the garage in Arizona so it’s had it’s own heat cycles as a result!
I can definitely open up the engine and take a look for rust.
I would have thought that the carbs would need servicing as I thought those diaphrams get questionable over time. Anthony gave me a pressure gauge to check the carbs but I don’t recall how to do this. Is there anywhere I can go to properly learn how to service the carburetors?
100% you’ll want to service the carbs.
This guy on YouTube has 2 good videos of re building the carbs. All the ibea kits are still available new aswell
The ibea l2 yellow power is a great carb too.
+1 on getting the big ends checked, when I got my dsc that had been sitting for a while the big end seized due to corrosion wasn’t a major issue as sorting it out would’ve been a new rod anyway
