I bet they would last for a short amount of time. Printed stuff is typically brittle and are porous. I bet with better materials it’d last longer but you’re probably better off going with metal.
I’ve printed a set in nylon. Been going strong for 2+ years. I use them as a backup in case the hub slips inward. I slip the hubs on with the spacers until they contact the axle then slide them out a mm or so.
That’s good to know. I haven’t messed with nylon yet, but that seems like a good use for it.
I just modified the prices to something a bit more entry level to hopefully get some sales flowing in. The 50% off sale is going to run through March 17th.
Nylon has its ups and downs. Had a buddy print them for me with his more skookem machine since it requires (or is just preferred?) a heated enclosure for good results
