Whats the recommended method for repairing a scrapped chassis? I’m handy with a grinder/ welder (notice which order I put those too in) Can I add metal to it slowly as to not overheat and make things brittle and/or warp?
Never heard it discussed, so I’m just curious what methods are employed.
So I popped for the Kart Lift metal chassis protectors. They seem very sturdy, but its a 3 piece kit, which I wish was a 4 piece kit so I could cover the cross bar between the seat and the fuel tank. (2nd picture)
I’ve used 30mm axle collars before on the cross bar between seat and tank worked pretty good and didn’t notice any issues with chassis performance or rubbing .
I love the metal ones, but they’ve been banned for safety reasons in more and more places and series - I guess a worn metal frame guard can slice through kart suits and skin and cause some nasty injuries when karts take to the air.
I was talking with a buddy just the other day about why no one has Kevlar frame protectors… Problem solved! I got a set of the plastic ones and just couldn’t bring myself to bolt them on, they are so thick! I felt like I would trade a minor rub for a major one with those things. Might have to give the Kevlar a go.
Just remember, if you drag the bottom off of the car, you can lower it more! (Actual conversation I had with an Indycar engineer, I wanted to kill him as I was fixing the bottom of the tub).
How did the Kevlar ones hold up? Did they stay put? I’m intrigued but worried about longevity of the adhesive and them staying put more than the wear surface. I guess you could put small hose clamps around them as extra protection but curious on your results after some use.
For the “budget minded”, you can buy a nylon cutting board cut judiciously, and use tapered head bolts that are countersunk to attach.
Or you can buy the nice KG molded plastic ones. I found a vendor who sells individually, so I bought 4, one for each side of the floorpan.
I still don’t like the violence of kerb hopping, and consider it technically “out of bounds” unless you’re floating the insides. I didn’t come from the Morgatto school of racecraft…
